IanPhillips
Jul 07, 2021Aspirant
Problems connecting RBS50Y
I am trying to install an RBS50Y Outdoor Orbi as a satellite to my house system. I successfully set up the RBS50Y - connected to my base station (an RBR40) no problem (Installed as an "Add-on Satell...
- Jul 19, 2021
Thanks for your suggestions
Tried all of this and got nowhere
Eventually had to go through the pain of a factory reset on my entire system and eventually figured out that the RBS50Y had switched into "range extender" mode rather than default Orbi mode - doing thsi requires some serious effort and I dont think I did it . but hey ho.
Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Appreciate your suggestions
Jul 07, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBSY?
Can you access the RBSYs web page with a PC and web browser?
YOu might turn OFF the other RBS and power cycle the RBSY and see if it gets connected and appears as connected in the RBRs web page.
- IanPhillipsJul 19, 2021Aspirant
- FURRYe38Jul 19, 2021Guru - Experienced User
Glad you got it working. Yes the RBSY works in two different modes.
Please mark your thread as solved so others will know.
Enjoy. :smileywink: - CrimpOnJul 19, 2021Guru - Experienced User
IanPhillips wrote:Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Might try moving the RBS20 and RBS50Y around a bit. WiFi is really sensitive to obstacles in the direct pathway. I had a "dead spot" that turned out to be because of a brick chimney going up the middle of the house that was casting a huge WiFi "shadow".
Does the Attached Devices display show the satellite connected to the router or to the RBS20?
