IanPhillips
Jul 07, 2021Aspirant
Problems connecting RBS50Y
I am trying to install an RBS50Y Outdoor Orbi as a satellite to my house system. I successfully set up the RBS50Y - connected to my base station (an RBR40) no problem (Installed as an "Add-on Satell...
- Jul 19, 2021
Thanks for your suggestions
Tried all of this and got nowhere
Eventually had to go through the pain of a factory reset on my entire system and eventually figured out that the RBS50Y had switched into "range extender" mode rather than default Orbi mode - doing thsi requires some serious effort and I dont think I did it . but hey ho.
Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Appreciate your suggestions
Jul 07, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBSY?
Can you access the RBSYs web page with a PC and web browser?
YOu might turn OFF the other RBS and power cycle the RBSY and see if it gets connected and appears as connected in the RBRs web page.
IanPhillips
Jul 19, 2021Aspirant
