IanPhillips
Jul 07, 2021Aspirant
Problems connecting RBS50Y
I am trying to install an RBS50Y Outdoor Orbi as a satellite to my house system. I successfully set up the RBS50Y - connected to my base station (an RBR40) no problem (Installed as an "Add-on Satell...
- Jul 19, 2021
Thanks for your suggestions
Tried all of this and got nowhere
Eventually had to go through the pain of a factory reset on my entire system and eventually figured out that the RBS50Y had switched into "range extender" mode rather than default Orbi mode - doing thsi requires some serious effort and I dont think I did it . but hey ho.
Sytem now rebuilt and RBS50Y working OK - although the distance to my garage (plus a couple of solid walls) makes the backhaul connection "poor" on a 2.4GH connection.
Appreciate your suggestions
IanPhillips
Jul 19, 2021Aspirant
Jul 19, 2021Guru - Experienced User
Glad you got it working. Yes the RBSY works in two different modes.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
