Rossana_Schneid
Dec 27, 2018Follower
Problems Downloading on Orbi Wifi - RBK43
Hello everyone,
I recently set up my Orbi system with 2 satellites. Everything is working great and we can access all the satellites which allows streaming of music and videos. The issue I am havin...
Dec 27, 2018Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Rossana_Schneid wrote:
Hello everyone,
I recently set up my Orbi system with 2 satellites. Everything is working great and we can access all the satellites which allows streaming of music and videos. The issue I am having is we are unable to download any content while on the Orbi Network. Even a simple task like updating an app on my phone while on the Orbi Network will not execute. Any Help or advice would be fantastic. Thanks!
