triple-t
Aug 03, 2017Aspirant
Problems Galaxy S8 Orbi RBR50 and Amazon Echo
Just in case anyone else experiencing this issue. Galaxy S8+ having similar connection problems, but after setting up my Orbi units tonight with noticable improvement in wifi speeds, I noticed half ...
DarrenM
Aug 04, 2017Sr. NETGEAR Moderator
We are investigating the issues with the S8
DarrenM
cyberprashant
Aug 04, 2017Luminary
My amazon echoes kept losing connections or not connecting at all with 1.12.0.18. Downgraded to 1.11.0.20 problem solved
- theallenuOct 03, 2017Aspirant
Just out of curiosity, when you downgraded to the previous firmware, does your S8 connect on the main network? I've had to use the hack on my system to turn on the guest network and have my S8+ connect to it. I've been doing that since the 1.12 version of the firmware, and with the latest 2.0.0.74, I tried connecting to my main network with the S8+ and the same problem. WiFi stays connected but internet drops. So, I've switched back to the guest network and it seems to be working fine, albeit very hacky.
I've had the system for about two weeks and debating if I'm going to keep it. The connectivity in the house is awesome, but weird bugs like this and also the fact that if I have several people streaming at the same time, it seems like one of the two will just drop everything and be like "That's it...I'm not doing all that"...and then I have to manually unplug and plug everything back in.
- triple-tOct 03, 2017AspirantVerizon released a patch for the s8, but it wasn't announced. ie no popup. this was probably a month ago and it fixed connectivity with my s8+.
Tom
