intgom
Oct 05, 2018Guide
Problems since switching ISP from Virgin to TalkTalk (UK)
Just switched from Virgin to TalkTalk and now having following issues when connected via Orbi:
- Cisco AnyConnect VPN won't connect
- random 404 errors on some web pages
- Can't download iOS ap...
Oct 05, 2018Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
intgom
Oct 05, 2018Guide
Thanks for the reply. NG router is on firmware version 2.2.1.210 and TalkTalk router is a Sagemcom FAST 5364 v 3.00.
Looks like Option 3 is the only one from your list that I can get going, though it makes no difference.
- FURRYe38Oct 05, 2018Guru - Experienced User
Does the sagecom modem/router have a DMZ?
- intgomOct 05, 2018Guide
Don't think so. All looks pretty standard in terms of network settings (DNS, DHCP, routing etc.). I've now established that there's definitely no modem-only mode on the Sagemcom so I might have a go at turning most of the network features/settings off manually and using a static IP on the NG router. Or do the AP-only thing mentioned above. But all of that can wait until tomorrow.
Thanks for all the responses so far - much appreciated.
If you can turn OFF items like uPnP, firewall and wifi on the modem, set up a reservation for the Orbi router on the modem, this could help. if not, I presume AP mode will be the best solution. This seems to be a limiting issue with the modem. Too bad DMZ isn't available on the modem.
Have a great evening.
