intgom
Oct 05, 2018Guide
Problems since switching ISP from Virgin to TalkTalk (UK)
Just switched from Virgin to TalkTalk and now having following issues when connected via Orbi:
- Cisco AnyConnect VPN won't connect
- random 404 errors on some web pages
- Can't download iOS ap...
Retired_Member
Oct 05, 2018
intgom wrote:
All work fine when connected to TalkTalk wifi so must be an Orbi or Orbi to TalkTalk router problem.
Perhaps not.
The only thing that you changed is your ISP (TalkTalk). Start there.
Also it looks like the Sagemcom FAST 5364 v 3.00 is a Modem/router combo which requires special setup to work with the ORBI ROUTER.
- intgomOct 05, 2018Guide
Sorry, should have been clear: ISP changed but also router (comes with the package). Virgin was cable, new router is ADSL.
- Retired_MemberOct 05, 2018
Thanks for that. How did you discover this / any idea where I can go to find out what is required? TalkTalk are being less than helpful :-(
