intgom
Oct 05, 2018Guide
Problems since switching ISP from Virgin to TalkTalk (UK)
Just switched from Virgin to TalkTalk and now having following issues when connected via Orbi:
- Cisco AnyConnect VPN won't connect
- random 404 errors on some web pages
- Can't download iOS ap...
intgom
Oct 05, 2018Guide
Sorry, should have been clear: ISP changed but also router (comes with the package). Virgin was cable, new router is ADSL.
Retired_Member
Oct 05, 2018
Also it looks like the Sagemcom FAST 5364 v 3.00 is a Modem/router combo which requires special setup to work with the ORBI ROUTER.
- intgomOct 05, 2018Guide
Thanks for that. How did you discover this / any idea where I can go to find out what is required? TalkTalk are being less than helpful :-(
- Retired_MemberOct 05, 2018
https://www.itwriting.com/blog/10843-talktalks-new-sagemcom-fast-5364-router-and-wifi-hub.html
Looks like you may need to set the Orbi in the AP mode. Many here on this forum can help with that. The Orbi manual should also provide guidance.
