intgom
Oct 05, 2018Guide
Problems since switching ISP from Virgin to TalkTalk (UK)
Just switched from Virgin to TalkTalk and now having following issues when connected via Orbi:
- Cisco AnyConnect VPN won't connect
- random 404 errors on some web pages
- Can't download iOS ap...
intgom
Oct 05, 2018Guide
Thanks for the reply. NG router is on firmware version 2.2.1.210 and TalkTalk router is a Sagemcom FAST 5364 v 3.00.
Looks like Option 3 is the only one from your list that I can get going, though it makes no difference.
Oct 05, 2018Guru - Experienced User
Does the sagecom modem/router have a DMZ?
- intgomOct 05, 2018Guide
Don't think so. All looks pretty standard in terms of network settings (DNS, DHCP, routing etc.). I've now established that there's definitely no modem-only mode on the Sagemcom so I might have a go at turning most of the network features/settings off manually and using a static IP on the NG router. Or do the AP-only thing mentioned above. But all of that can wait until tomorrow.
Thanks for all the responses so far - much appreciated.
- FURRYe38Oct 05, 2018Guru - Experienced User
If you can turn OFF items like uPnP, firewall and wifi on the modem, set up a reservation for the Orbi router on the modem, this could help. if not, I presume AP mode will be the best solution. This seems to be a limiting issue with the modem. Too bad DMZ isn't available on the modem.
Have a great evening.
