rhett7660
Sep 07, 2018Aspirant
Problems with AP mode but DHCP is still ON
Hello,
I have my Orbi setup in AP mode however the settings are still showing DHCP has ON. I have gone in and switched it back to "Router" mode, gone back under the Setup-LAN Setup and uncheck...
- Sep 07, 2018
Mine does, yes. It evidently means DHCP client mode, not DHCP server mode. As in AP mode with dynamic IP versus fixed IP.
Unless the OP has indication the Orbi is handing out DHCP addresses in AP mode (which it does not do), there is nothing to be concerned about.
Sep 07, 2018Guru - Experienced User
So the UI will show DHCP enabled even though in AP mode?
st_shaw wrote:
DO NOT reset and start from Scratch. What you see is normal but maybe confusing. It says DHCP ON becase the Orbi is set to receive its IP address via DHCP from your router.
st_shaw
Sep 07, 2018Master
