ProgCobol
Jul 16, 2021Guide
Problems with logging directly in to RBW30
When I try to login to the webpage for my just acquired RBW30 using the IP address I get username and password errors. I can login directly to my RBS40V satellite with no issues using the same userna...
- Jul 17, 2021
Success! I can log in to my RBW30 web page by using admin/password as the credentials. Once I logged in, I was able to update the RBW30 to the latest firmware.
ProgCobol
Jul 16, 2021Guide
Yes, the RBW30 shows up just like the RBS40V as a connected satellite. The Backhaul Status is good and the Connection type is 5ghz.
CrimpOn
Jul 16, 2021Guru - Experienced User
ProgCobol wrote:Yes, the RBW30 shows up just like the RBS40V as a connected satellite. The Backhaul Status is good and the Connection type is 5ghz.
What a puzzle. Sometimes things "shake out" if every device is powered off and then back on, starting with the router.
Otherwise, "I got nothin"
