Pheckphul
Mar 16, 2020Tutor
Problems with new Orbi RBK53 setup
I am attempting to replace my old Open-Mesh setup with an Orbi RBK53 setup. I have the RBR50 setup as an AP connected to my LAN behind a separate router (Sophos UTM), and the two RBS50s connected to ...
- Mar 18, 2020
Sorry to waste your time. Turns out I had accidentally plugged the LAN into the RBR50's WAN port, instead of one of the LAN ports. :smileysad: Once I discovered that, the satellites connected to the RBR50 via Ethernet.
Pheckphul
Mar 18, 2020Tutor
Mar 19, 2020Guru - Experienced User
Glad its working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Pheckphul wrote:Sorry to waste your time. Turns out I had accidentally plugged the LAN into the RBR50's WAN port, instead of one of the LAN ports. :smileysad: Once I discovered that, the satellites connected to the RBR50 via Ethernet.
