willyski
Oct 24, 2019Tutor
Problems with RBR50 and RBS50
I have been wrestling with this for the past week and spent the last two days resetting my router and then reconnecting all my devices. It appears this issue occurred with the last firmware update 2...
- Oct 24, 2019
Ensure the wifi radios on this routers is FULLY turned OFF.
Are you resetting both RBR and RBS? Back reset button for 15 seconds then let go?
You can setup the RBR first for AP mode configuration with out it being connected to the main host router. Just connect a wired PC to the RBR and set up from there, once all setup on the RBR, power off and connect it to the main host router. Check with a wifi analyzer on a PAD if you have one to see that each radio is broadcasting from the RBR. 2.4 and 5Ghz SSIDs should be seen.
I would setup the RBR first for AP mode. Get it configured and online with the main host router. Once setup, give it some time. Then setup the RBS.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Are they using any channels the Orbi system is using?
Nov 03, 2019Guru - Experienced User
Any progress on this? Hope this has helped...
willyski wrote:I have been wrestling with this for the past week and spent the last two days resetting my router and then reconnecting all my devices. It appears this issue occurred with the last firmware update 2.5.0.38. My satellite is only broadcasting in th 5g range and none of my devices that use to connect to it no longer can. I got everything working yesterday but today I lost connectivity again. My main router, the RBR50 is hardwared to a gateway so I have it set up as an AP point. The Satellite, RBS50 is wified to the Orbi RBR50. I am at wits end.
willyski
Nov 03, 2019Tutor
I did find out that when I was reseting the Orbi, I was not holding the reset button long enough. The problem went away for a few days and then reemerged. I went into my settings and changed the frequency from Auto to a specific channel and immediately saw the results. Thanks a lot for the tips.
- FURRYe38Nov 03, 2019Guru - Experienced User
AH ok. Yes, 15 seconds is recommended press with the back reset button, then let go.
Glad it's working for you now.
Enjoy.
