Manguinhas
Jan 12, 2019Aspirant
Problems with Steam Link
Hi all.
I have a brand new RBR20 connected to my ISP router, with ethernet backhaul to a sattelitte in my living room, where I have a Steam Link connected with ethernet to the sattelite.
The ...
- Jan 24, 2019
Hey, I got it working with the 3rd solution you provided, but I was trying the second solution, in order not to lose the router capabilities:
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
I've done this, but my steam link still doesn't find my desktop.
I've attached a sceenshop of the DMZ config.
ekhalil
Jan 12, 2019Master
Of course it won’t find it since I believe that each device belongs to different network.
You have to either bridge the ISP router or set Orbi in AP mode.
