Manguinhas
Jan 12, 2019Aspirant
Problems with Steam Link
Hi all.
I have a brand new RBR20 connected to my ISP router, with ethernet backhaul to a sattelitte in my living room, where I have a Steam Link connected with ethernet to the sattelite.
The ...
- Jan 24, 2019
Hey, I got it working with the 3rd solution you provided, but I was trying the second solution, in order not to lose the router capabilities:
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
I've done this, but my steam link still doesn't find my desktop.
I've attached a sceenshop of the DMZ config.
Manguinhas
Jan 14, 2019Aspirant
Thanks for the answer.
I switched orbi to AP mode and got it working. I now have acess to my desktop.
I lost the ability to switch off an individual device through the orbi app. Was that supposed to happen?
ekhalil
Jan 14, 2019Master
Yes, that is expected. The following router features are not available (grayed out) when the router is in AP mode:
- Guest Network
- QoS
- Setup Wizard
- Port Forwarding/Port Triggering
- Remote Management
- UPnP
- IPv6
- Traffic Meter
- Parental Controls
- Block Sites
- Block Services
- VPN service
- VLAN/IPTV setup
- Internet Setup
- WAN Setup
- LAN Setup
