Manguinhas
Jan 12, 2019Aspirant
Problems with Steam Link
Hi all.
I have a brand new RBR20 connected to my ISP router, with ethernet backhaul to a sattelitte in my living room, where I have a Steam Link connected with ethernet to the sattelite.
The ...
- Jan 24, 2019
Hey, I got it working with the 3rd solution you provided, but I was trying the second solution, in order not to lose the router capabilities:
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
I've done this, but my steam link still doesn't find my desktop.
I've attached a sceenshop of the DMZ config.
Manguinhas
Jan 24, 2019Aspirant
Jan 24, 2019Guru - Experienced User
Good to hear. Glad you got it work.
Possible that the ISP modems DMZ may not be fully giving pass thru traffice and inhibiting some thing. DMZ can vary from modem Mfr to Mfr.
Besure to mark your post as solved so others will know.
Enjoy. :smileywink:
