Retired_Member
Jun 30, 2020Product compatibility
Is the RBW30 satellite compatible with the RBR50 Orbi AC3000 Tri-band router? Thanks in advance. Stu
CrimpOn
Jun 30, 2020Guru - Experienced User
Yes, indeed. It is compatible.
Retired_Member
Jun 30, 2020V2, as well. Thanks.
