pauldmartinez
Feb 21, 2021Aspirant
Product Model: RBR10
Hello. I am wondering if i can turn off the 5ghz part of the router/mesh and just use the 2.4ghz on my RBR10 along with the other satellites i have attached to the RBR10?
pauldmartinez
Feb 22, 2021Aspirant
Thank you for your reply. So tell me if i am wrong but i am installing Feit Light wifi Switches and on the packaging it says only compatible with 2.4ghz and has a X thru the 5ghz. So if this is the case it sounds like i would have to change from my RBR10 Router and Satellites to another system that will allow me to turn off the 5ghz. Please advise and thank you in advance.
CrimpOn
Feb 22, 2021Guru - Experienced User
pauldmartinez wrote:Thank you for your reply. So tell me if i am wrong but i am installing Feit Light wifi Switches and on the packaging it says only compatible with 2.4ghz and has a X thru the 5ghz. So if this is the case it sounds like i would have to change from my RBR10 Router and Satellites to another system that will allow me to turn off the 5ghz. Please advise and thank you in advance.
I have purchased a couple of Feit smart plugs. What the packaging is saying is that the product will work only if there is a 2.4G WiFi network. This is similar to a product saying "requires 2 AA batteries." No AA batteries? Won't work.
The Orbi HAS a 2.4G WiFi. The product cannot detect anything but 2.4G WiFi. The fact that the Orbi also has 5G WiFi is of no interest to the Feit product.
As an aside, I found the Feit smartphone app cumbersome because I did not realize at one point that what it wanted me to input was the passsword for the Orbi WiFi. I thoght the app was a bid "brain dead". However, once that issue was ironed out, the Feit smart plugs connected to my Orbi just fine.
- pauldmartinezFeb 25, 2021Aspirant
Thanks a million for this response! This makes sense. I will keep in mind the app being cumbersome. I will revisit this and get the FEIT Switches online! Ill let you know how it goes
- CrimpOnFeb 25, 2021Guru - Experienced User
Will be interested to see how the Feit "smart switch" installation goes. My only concern would be if the electrial box is metal (which would interfere with WiFi signals). The vast majority of electical boxes installed in the last 50-60 years have been plastic, so that is probably not going to be an issue for you.
I have "outdoor" smart plugs from several companies, and I was disappointed that the Feit outdoor plug does not allow control of the two outlets individually (as my Tekin and Kasa plugs do).
Fortunately our house was built last year and it definitely has plastic boxes.
what do you mean that your outdoor FEIT switches dont control 2 outlets individually? thanks for elaborating
