jarlag
Jul 30, 2020Follower
Product Selection
I need advice on production selection for WiFi Router, preferably (if it makes sense) for the new Orbi 6. My current setup is very old and starting to fail. The setup is as follows: One Airport Extreme with an Ethernet cable into the Modem. Also, and Ethernet cable from the Airport Extreme to a TrenNedt TPL-307E extender that is plusged into the wall. This is all in one room together. There is another TrendNet in a home office not far from the room the Aiport Extreme is that is plugged into the wall and it is ethernet cabled into a D-Link Switch that is Giga-Bit POE. The D-Link Switch has a VOIP office phone connected in it and a Cloud Based external Hard Drive. Also in the house is a NetGear EX 7300 extender that is plugged into the wall in awalk out basement where there is a Smart TV to access it as well as other WiFi devices that can not get a signal from the Airport Extreme. Finally, there is an Airport Express that is hooked into a Pre-Amp and Amp in order to play iTunes and other items through the stereo system.
How can i get the right configuration from NetGear to replace all this and still have the same functionality?
1 Reply
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-SystemsModem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-SystemWhat is the size of your home? Sq Ft?
