blainep3
Dec 25, 2018Aspirant
product support contact info
Just purchased the Orbi RBK22 and setup. Have some issues that I would prefer to talk to tech support about but absolutely cannot even find email or chat contact info, much less a phone number for t...
ekhalil
Dec 26, 2018Master
If you registered your product then all you need to do is to go to "My Netgear" web page: https://www.netgear.com/mynetgear/registration/login.aspx
Once you login you can choose "Get help on my Netgear product" in the following menu:
Select the registered product that you need help with, you will get a number of suggestions, if you select to contact support then you will be asked about the preferred way of communication, you can select either to open a ticket, email or call. If you select to call then you will be asked to give a description to your issue before giving you the local phone number.
Good luck!
- blainep3Dec 26, 2018Aspirant
Thanks for the reply. I don't ever get the options for support shown in your example. See my screenshot.
- ekhalilDec 27, 2018Master
I could not see the snapshot that you psted. I think it takes time until a moderator approves the picture.
But, I did not mention that before getting to those options, after you log in you need to select "My Support" and then the "Contact Support" option will be visible, when you click Contact Support you will get the options that I showed earlier. Please see below:
- DoggieCMJan 19, 2019Aspirant
when i click on get support nothing happens
