blainep3
Dec 26, 2018Aspirant
product support contact info
Just purchased the Orbi RBK22 and setup. Have some issues that I would prefer to talk to tech support about but absolutely cannot even find email or chat contact info, much less a phone number for t...
DoggieCM
Jan 20, 2019Aspirant
when i click on get support nothing happens
ekhalil
Jan 20, 2019Master
So what happens after clicking on "Contact Support" in the following page:
You should get the following page:
Then if you select "Get Help on my NETGEAR product" you should get the following page:
Where you can select one of your registered products from the drop down menu. After that you'll get "Suggested Answers from our Knowledge base:"
If you don't find any answer to your issue then you can click on "I cannot find an answer to my problem, I would like to contact NETGEAR support" so you will get a number of contact alternatives as follows:
I hope that this helps!
Good luck
