blainep3
Dec 25, 2018Aspirant
product support contact info
Just purchased the Orbi RBK22 and setup. Have some issues that I would prefer to talk to tech support about but absolutely cannot even find email or chat contact info, much less a phone number for t...
geordieinafrica
Jan 31, 2019Aspirant
Hi
I get exactly the same problem, i.e. in my account, I press 'My Support', then hit the blue 'Contact Support' button and nothing happens.. just left with blank white space below the button..
I need support as my extra satellite RBS40 is working fine, but is invisable on the app
Jan 31, 2019Guru - Experienced User
Try using a different browser. I'm using Opera and pressing My Support shows the page and a blue button for Contact Support.
geordieinafrica wrote:
Hi
- geordieinafricaJan 31, 2019Aspirant
Hi Furry
Now why did I not think of that !?
I was using Chrome, I tried on Firefox and it worked perfectly.
Thank you
Ticket now issued to support
- FURRYe38Jan 31, 2019Guru - Experienced User
Good Luck and hope they can help you get things running for you. :smileywink:
Hi Furry
Thank you
