Gellie
Jun 21, 2018Aspirant
Proper channel
I have my orbi connected to a Verizon Actiontec router that is selected on channel 5. Should I leave my Orbi on automatc or should I select a channel that has less traffic in my neighborhood? I am no...
Gellie
Jun 22, 2018Aspirant
Thanks. I would like to try that. How do I put the orbi in AP mode?
Gellie
Ok found it. Do I also need to "I would disable MIMO, Daisy Chain and Fast Roaming as well. "?
right now i have the following checked:
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices | |
| Enable MU-MIMO | |
| Enable Fast Roaming |
- MozezJun 22, 2018Guide
Hi Gellie,
Personally, I have all mine checked and I don't experience issues with my devices dropping off the Wi-Fi network. If you do (in particular, older Wi-Fi devices), you should leave those unchecked.
I see them as: checked for performance and unchecked for stability.
- FURRYe38Jun 22, 2018Guru - Experienced User
Leave Beamforming enabled. If you have any known MIMO supporting devices you can enable this as well, if not, disable it and Fast Roaming. Daisy Chain is for two or more satellites set up in a line piggybacking off each other. I recommend disabling this for now.
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO Enable Fast Roaming - GellieJun 22, 2018Aspirant
Also are these drops normal?
