hunnu
Apr 24, 2024Follower
ProtonVPN on Orbi RBR50 with Voxel Firmware?
Hello
I recently updated my Orbi RBR50 to the latest custom Voxel firmware. I am now trying to run a VPN in the router for the entire network. I read Voxels instructions but I am too much of a noob to do it right.
Is it taking a USB, formatting it to EXT4, putting the OpenVPN profile in a folder (the one recommended by Voxel) and pasting the OpenVPN config file in there?
Or is it something else?
If anyone has done this with ProtonVPN, is there anything else I should add to the config file ?
Thanks for your help and appreciate other suggestions if there’s a better way.
1 Reply
You'll have to post on the voxel forum.
The official forums only support stock firmware (which doesn't support proton)
