LowDawg
May 26, 2020Aspirant
PS4 and Netflix issues
recently switched from AT&T to Xfinity and bought a new router (CM500) and hooked it up to existing Orbi system. No problems with phones or email, but we cannot hook up to playstation and some of ou...
- May 27, 2020
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
May 27, 2020Guru - Experienced User
Have you powered OFF the modem and RBR for 1 minute then back on?
Is Armor or Circle enabled on the RBR?
- LowDawgMay 27, 2020Aspirant
Orbi firmware = V2.5.1.8
yes have rebooted several times, no effect
yes on armor, not really sure how/why when I reset the system back up it was turned on, not sure how to turn it off.
Not sure what circle is.
thanks for the reply
- FURRYe38May 27, 2020Guru - Experienced User
I would factory reset the RBR and walk thru the setup wizard. After you complete the setup wizard you'll be presented with a Armor enable window. I would not enable Armor here. See if this helps get the PS connected better.
thanks, I will give that a try. Can you use the Orbi app for the reset?
