LowDawg
May 26, 2020Aspirant
PS4 and Netflix issues
recently switched from AT&T to Xfinity and bought a new router (CM500) and hooked it up to existing Orbi system. No problems with phones or email, but we cannot hook up to playstation and some of ou...
- May 27, 2020
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
May 27, 2020Guru - Experienced User
No, it can only reboot the RBR. Either reset using a PC and web page and use the ERASE feature on the RBRs web page or press the reset button for 15 seconds then release.
