AmtrHomeNetAdm
Oct 04, 2019Tutor
ps4 cannot identify NAT type while on Orbi satellite
I have an Orbi mesh setup (1 router, 2 satellites). This is a new setup, replacing old my router. The Orbi router is my router and is directly connected to my ARRIS cable modem. The only wifi in the...
- Oct 09, 2019
No. Its not. Having a game console in the guest network could be since Guest Network which has less controls.
AmtrHomeNetAdm
Oct 05, 2019Tutor
Single private ip from each location. So the satellite is not creating a double NAT.
ekhalil
Oct 05, 2019Master
So does the traceroute give the same results (same path, same IP addresses) from when done from satellite as when done from router?
Also what is the model of the Arris cable modem?
- AmtrHomeNetAdmOct 05, 2019Tutor
trace routes are identical. ARRIS modem is a SB6183.
- ekhalilOct 05, 2019Master
ou mentioned that you have done the port forwarding to PS4 in Orbi:
- Which ports have you forwarded in Orbi?
- Have you done an IP address reservation in Orbi for the PS4 or have you set a static IP address for the PS4 in PS4?
port fowarding the following for IP associated with our ps4 (udp & tcp) : 80, 443, 3478-3480
i haven't reservered an IP, nor set a static IP for our ps4. It has consistently had the same IP address resevation.
Note this Orbi setup is only a week old.
And remember, everything works perfectly when the ps4 directly connects to the Orbi router. This is a "only when connected to the satellite" issue.
