whiteknucle
May 19, 2020Aspirant
PS4 connect to Orbi (get IP) but won't connect to Internet
I'm having this issue since I got the Orbi router. PS4 refuses to connect to Internet through the Orbi router. I've been trying every configuration trick I found so far and none seem to work. M...
Tenoates
May 19, 2020Tutor
Have you tried enabling uPNP on the orbi?
Orbi Settings > Advanced > Advanced Setup > UPnP
whiteknucle
Yup, it's been ON from day one. Tried disabling/re-enabling with restarts in between (both Orbi and PS4), nothing really changes
This is turning to be one of the most frustrating routers I've had
