OranB16
Jul 09, 2020Aspirant
PS4 has stopped connecting to my Orbi RBR50
For a while my PS4 has been working perfectly fine with my Orbi until two nights ago my dad turned off its internet connection as I was being too loud so he wanted me to go off, he does this quite oft...
Jul 09, 2020Guru - Experienced User
Did he block it in access control or in the app? He might need to unblock it from there.
- OranB16Jul 09, 2020AspirantOn the app it says that it is connected to the internet but when I run an internet test on the PS4 it says it’s not connected
- plemansJul 09, 2020Guru - Experienced User
Again, how did he block access? Was it through the app, through parental controls, using access controls?
was it through his app setup (not yours)?
- OranB16Jul 09, 2020AspirantHe turned it off through the app on device manager where he you just tap the switch next to the PlayStation to turn it off
