OranB16
Jul 09, 2020Aspirant
PS4 has stopped connecting to my Orbi RBR50
For a while my PS4 has been working perfectly fine with my Orbi until two nights ago my dad turned off its internet connection as I was being too loud so he wanted me to go off, he does this quite oft...
OranB16
On the app it says that it is connected to the internet but when I run an internet test on the PS4 it says it’s not connected
Jul 09, 2020Guru - Experienced User
Again, how did he block access? Was it through the app, through parental controls, using access controls?
was it through his app setup (not yours)?
- OranB16Jul 09, 2020AspirantHe turned it off through the app on device manager where he you just tap the switch next to the PlayStation to turn it off
- plemansJul 09, 2020Guru - Experienced UserAnd did he go back in on his device to re-enable it?
- OranB16Jul 09, 2020AspirantYes and he went back on the next day and he turned it on, I have also just spoken to the PlayStation customer service and they eliminated all the possibilities that it was something on their side.
