gpburdell22032
Mar 03, 2019Follower
PS4 Refusing to connect to Orbi RBK50 WiFi - Alternate solution
I recently purchased an RBK50 and in the process of setting up devices encountered an issue where the PS4 would issue an error on attempting to connect. In reviewing the forums here I found "PS4 Refu...
Mar 03, 2019Guru - Experienced User
What WPA security modes are you using?
Try enableding Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
gpburdell22032 wrote:
I recently purchased an RBK50 and in the process of setting up devices encountered an issue where the PS4 would issue an error on attempting to connect. In reviewing the forums here I found "PS4 Refusing to connect to Orbi WiFi"; however, that solution suggested rolling back the firmware.
I found that setting up a static IP for the PS4 on the Orbi resolved the issue for me, and I could connect through the easy setup of the PS4. Setting up the static IP was performed on the Orbi's web interface by going to Advanced/Setup/Lan Setup/Address Reservation. I entered the PS4 MAC address obtained for its wifi by reviewing this within the PS4 internet connection setup. My current firmware v2.2.1.210.
