paulb73
Jan 29, 2019Initiate
PS4 Refusing to connect to Orbi WiFi
Hi Folks
For some reason my PS4 is refusing to connect to my Orbi WiFi network. It has previously worked fine (though I haven’t used it in a while). When I go through the network configuration ...
- Jan 29, 2019
It's not you! It's the newer FW. My PS4 dropped every 2-5 minutes. Had to go back to ethernet.
Don't waste your time breaking yout PS4.
Instead. Roll back your Orbi FW and the problem will likely resolve itself.
ekhalil
Jan 29, 2019Master
I saw this issue reported frequently from PS4 users. The following solutions were always suggested:
Solution #1:
On your PS4, go to [Settings] > [Networks] > [Set Up Internet Connection] > (Use WiFi) > (Easy). When asked which Wi-Fi network you want to use, scroll down to the bottom and select [Set Up Manually]. Select (Enter Manually) and enter your Orbi's SSID, followed by your network's password.
Solution #2:
Restart your PS4 in Safe Mode and select option 4 [Restore Default Settings]. When your system restarts try connecting to your Wi-Fi access point again.
Good luck :)
