RawEddie
Feb 16, 2021Aspirant
PS4 won't connect to my Orbi RBR10
*Note: my mesh system id the RBR10/RBS10, it won't find it on the model search bar* My PS4 won't connect to my new Orbi router, when trying to connect to the network it gives me a "DNS not found" i...
vajim
Feb 16, 2021Master
RawEddie wrote:My ps4 does support both freqs, and what do you mean? do you want a picture or want me to describe it.
no that's ok.....if your PS4 supports both freqs then it should connect.
i have the xbox one and i just hooked it up and gave it the orbi password and it connected.
RawEddie
Yeah, thats why i kinda forgot about it, the extender connected via Ethernet to the main ORBI then from there connecting the PS4 to the 5Ghz band that the Extender is giving works fine, but at the cost of convenience, and slower wifi.
- vajimFeb 16, 2021Master
RawEddie wrote:Yeah, thats why i kinda forgot about it, the extender connected via Ethernet to the main ORBI then from there connecting the PS4 to the 5Ghz band that the Extender is giving works fine, but at the cost of convenience, and slower wifi.
for now while you try to fix the PS4 I would drop the extender and try the orbi alone.
here's another read...you're not alone:
https://community.netgear.com/t5/Orbi-AX/NETGEAR-ORBI-connection-drops-with-PS4/td-p/1871923
in the thread above there are forum contacts that might be able to help.
or you can keep playing the 1000 questions game
good luck
