RawEddie
Feb 16, 2021Aspirant
PS4 won't connect to my Orbi RBR10
*Note: my mesh system id the RBR10/RBS10, it won't find it on the model search bar* My PS4 won't connect to my new Orbi router, when trying to connect to the network it gives me a "DNS not found" i...
Feb 16, 2021Guru - Experienced User
Try turning down the power output of the RBRs 2.4Ghz wifi radios from 100% to 25%, reboot the PS console after the change and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You might turn Off any RBS temporarily while checking this.
RawEddie wrote:That can or is most probable, but if i had my old router from my ISP, the PS4 would connect with the 5GHz band no problem. May i say that the first Generation of PS4's didn't support the 5GHz band but i have the Slim edition which does.
