DCP4971
Aug 04, 2021Luminary
PS5 Speed test
Hi all, Have RBR50 and 2x RBS50s. Plugged into cable modem (Arriss something or other) in modem mode - I recently changed this to modem from router, via factory reset. I have a 1gig contract ...
Aug 12, 2021Guru - Experienced User
Is the PS the one wired device that experiences this thru the RBR?
Do other wired devices see same problem? Use a wired PC or laptop?
DCP4971
Aug 12, 2021Luminary
Hi, thanks for the reply, so;
Firmware is V2.7.3.22
ISP modem is apparently an Arriss TG3492LG-VMB
The PS5 is wired, using Cat7 cable.
Where I have tested other devices wired, it only seems to occur on the PS5 (I have a MacMini permanently wired and this runs at 800-950mbps when testing, other laptop when I have tested is equally speedy).
Cheers
- FURRYe38Aug 12, 2021Guru - Experienced User
Is Armor, Circle or IPv6 enabled on the RBR?
