DCP4971
Aug 04, 2021Luminary
PS5 Speed test
Hi all, Have RBR50 and 2x RBS50s. Plugged into cable modem (Arriss something or other) in modem mode - I recently changed this to modem from router, via factory reset. I have a 1gig contract ...
DCP4971
Aug 12, 2021Luminary
Hi, thanks for the reply, so;
Firmware is V2.7.3.22
ISP modem is apparently an Arriss TG3492LG-VMB
The PS5 is wired, using Cat7 cable.
Where I have tested other devices wired, it only seems to occur on the PS5 (I have a MacMini permanently wired and this runs at 800-950mbps when testing, other laptop when I have tested is equally speedy).
Cheers
Aug 12, 2021Guru - Experienced User
Is Armor, Circle or IPv6 enabled on the RBR?
- DCP4971Aug 13, 2021Luminary
Factory reset has been done. No Circle (but Netgrear Parental Controls is active), Armour is disabled. IPV6 is not enabled.
Thanks
- FURRYe38Aug 13, 2021Guru - Experienced User
What happens if you disable SPC?
Thanks for the suggestion, doesn't seem to make any difference. Also just disconnected all the other wired stuff and still speeds were really slow. Reconnected everything and MacMini, wired, still flying at 934mbps..
