nh2018
Feb 13, 2018Follower
Pt to Pt WiFi backhaul between two outdoor satellites supported?
I want to add outdoor satellites (RBS50Y) between houses roughly 200 to 225 feet apart, and extend my existing orbi network across to that second structure, and then have that far end outdoor satelli...
DarrenM
Feb 14, 2018Sr. NETGEAR Moderator
Yes you can daisy chain the satellites with daisy chaining enabled on the router this may work but it all depends on your environment and if the signal will reach as far as you need it to.
DarrenM
