sam_reitich
Jun 04, 2019Tutor
Public IP to a Minecraft Server Port Forwarding
Hi, So I'm trying to create a Minecraft server for my friends and I cause I'm a nerd. I've set everything up right Minecraft-wise, because the localhost works fine. However, trying to connect to ...
Jun 04, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- sam_reitichJun 04, 2019Tutor
Is there a guide anywhere to explain how to do the first option? I'm not very experienced in computer hardware.
- FURRYe38Jun 04, 2019Guru - Experienced User
You'll need to contact the ISP to see if this option can be supported on there modem. Some modems don't support bridging so if thats the case, you can try option #2. Option #3 lastly.
I have no clue what you just said
