sam_reitich
Jun 04, 2019Tutor
Public IP to a Minecraft Server Port Forwarding
Hi, So I'm trying to create a Minecraft server for my friends and I cause I'm a nerd. I've set everything up right Minecraft-wise, because the localhost works fine. However, trying to connect to ...
Jun 04, 2019Guru - Experienced User
You'll need to contact the ISP to see if this option can be supported on there modem. Some modems don't support bridging so if thats the case, you can try option #2. Option #3 lastly.
sam_reitich
Jun 04, 2019Tutor
I have no clue what you just said
