twm1969
May 07, 2018Follower
Purchase Advice Needed
Greetings!
I am the proud new owner of Gig internet speed from Comcast / XFinitiy. Through Ethernet I am getting consistently 900MB plus, which is great. On 5G wireless it ranges from about 7...
st_shaw
May 07, 2018Master
Keep in mind that Orbi has a maximum WiFi link speed of 866 Mbps on 5 GHz. You will only see 50-60% of that in wireless throughput, under ideal conditions. This means the most you will ever see is around 500 Mbps, and that would be right next to the Orbi router.
- tsigMay 08, 2018Luminary
Sitting in my living room where my main unit is located, the Orbi app gives me a link speed of >800 Mbps. My internet is only a 50/50 service though so no way to test it.
