jdpg2
Apr 24, 2018Apprentice
Purple solid ring on router but router performs perfectly...
So my Orbi has been working flawlessly since the latest firmware but i just noticed that the ring on the router is solid purple. The router is in AP mode and i have had zero drop issues and its been...
jdpg2
FW: 2.1.3.4
Have it sorted the WAN cable was pluged in to the switch, not the network port. Just moved the cable on the Orbi and rebooted and light out.
Apr 24, 2018Guru - Experienced User
Kewl.
Be advised there is newer v2.1.4.10 FW now for 50 series systems:
https://kb.netgear.com/000055985/RBR50-RBS50-Firmware-Version-2-1-4-10
Up to you if you wanna try it.
