statman66's avatar
May 30, 2018
P/W Reset Questions
Q1:  What is the name of your first Netgear product?  Is this a trick question?  I'm sure it was not a question selected by me.  Is the anser on my router somewhere?
  • FURRYe38's avatar
    May 30, 2018
    There is no login needed after the factory reset. The set up wizard starts here immediately.
