statman66
May 30, 2018Tutor
P/W Reset Questions
Q1: What is the name of your first Netgear product? Is this a trick question? I'm sure it was not a question selected by me. Is the anser on my router somewhere?
- May 30, 2018
There is no login needed after the factory reset. The set up wizard starts here immediately.
May 30, 2018Guru - Experienced User
- statman66May 30, 2018Tutor
Did all this and now refuses to go to the orbilogin.net or com site. Takes me to netgear site. Am trying to clear Chrome, but doesn't want to clear. Help!
- FURRYe38May 30, 2018Guru - Experienced User
Disconnect the WAN cable from the wan port on the Router. Then try 192.168.1.1 after a factory reset. Try IE11 or FF browser.
Tried that. FF won't download. I have a Mac so tried Safari. No luck. BTW, MAC says my IP address i 10.224.0.1
