statman66
May 30, 2018Tutor
P/W Reset Questions
Q1: What is the name of your first Netgear product? Is this a trick question? I'm sure it was not a question selected by me. Is the anser on my router somewhere?
- May 30, 2018
There is no login needed after the factory reset. The set up wizard starts here immediately.
May 30, 2018Guru - Experienced User
Any chance of getting this modem bridged or replaced with a modem only?
This is a gateway modem so it has a built in router already with wifi:
This is why your seeing 10 IP address on your PC thats connected to the Orbi, the modem is using 192.168.1.x pool and the Orbi auto adjusted for something different as it can't use the same IP pool as the modem.
I believe you can BYOM with xfinity.
Other option would be to use the modems DMZ for your Orbi router while using the Orbi in router mode, or configure the Orbi for AP mode.
statman66
May 30, 2018Tutor
I knew that, but need the satellite to cover may daughter's bedroom a couple of concrete walls away from the main router. Really didn't have any problems until I tried to log into it and found I'd forgotton my P/W. I can try, but have you ever tried dealing with Xfinity?
- FURRYe38May 30, 2018Guru - Experienced User
LOL no. Understand. Well if you don't wanna deal with Xfinity, you can use the DMZ for the Orbi router in router mode or configure it for AP mode. Either of these methods will work. You'll still have use and operation of the satellite as needed.
- statman66May 30, 2018Tutor
Very cool. Thank you for your help and your patience.
Good Luck and Enjoy. :smileywink:
