troutteaser
Aug 12, 2019Guide
QoS for Orbi RBR40
I have an Orbi RBR40 and Spectrum internet with 400 mbps, but I am having intermittent issues with voice quality for VOIP (webex, skype etc..) calls. I don't see a QoS setting for the RBR40. Are th...
Aug 14, 2019Guru - Experienced User
Any progress on this?
troutteaser wrote:I have an Orbi RBR40 and Spectrum internet with 400 mbps, but I am having intermittent issues with voice quality for VOIP (webex, skype etc..) calls. I don't see a QoS setting for the RBR40. Are there any other settings I can change to try and improve the robotic voices and video freezing. Happens for both ethernet and wifi connections.
- troutteaserAug 14, 2019Guide
Yesterday I removed my existing two satellites and factory reset my RBR40. Then added two new replacement satellites to my Orbi mesh system. So far things are working, but time will tell. Thank you for following up.
- FURRYe38Aug 14, 2019Guru - Experienced User
So bad RBS huh? Interesting. Glad you got it working.
Please mark your thread as solved so others will know.
Enjoy.
I think it is a bit premature to say my issue is solved. I'll give it a few weeks and see how things go. Regards.
