RonV42
Dec 20, 2016Luminary
QOS on Orbi is it enabled or disabled?
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled. Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off. We need a che...
- Retired_MemberDec 26, 2016
Worked. The HTML has to be changed to HTM.
peteytesting
Dec 20, 2016Hero
when you run the speed test it asks you if you want to set the speed test as the qos on the latest fw , this is then used as auto qos
- RonV42Dec 20, 2016Luminary
It never asks to question to use it just displays the results on the page...I assume it's using it but again there needs to a way to turn off and on.
- peteytestingDec 20, 2016Hero
i think at this stage you would have to factory reset
setting the max qos is a good thing anyway as it stops any one device from hoging the whole bandwidth
Reset to factory isn't a acceptable solution. It would be like asking me to replace my car engine after I did maintenance.
