RonV42
Dec 20, 2016Luminary
QOS on Orbi is it enabled or disabled?
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled. Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off. We need a che...
- Retired_MemberDec 26, 2016
Worked. The HTML has to be changed to HTM.
RonV42
It never asks to question to use it just displays the results on the page...I assume it's using it but again there needs to a way to turn off and on.
peteytesting
Dec 20, 2016Hero
i think at this stage you would have to factory reset
setting the max qos is a good thing anyway as it stops any one device from hoging the whole bandwidth
- RonV42Dec 20, 2016Luminary
Reset to factory isn't a acceptable solution. It would be like asking me to replace my car engine after I did maintenance.
- dg_sticksDec 22, 2016Guide
This is killing me! I believe that the lack of QoS options are holding my LAN speeds back dramatically, but I have no way to verify since I have zero options on the QoS page other than the speedtest. I believe that the factory reset is ridiculous as well. Does anyone have a solution to get the QoS page to show all options?
- Dan_HDec 23, 2016Apprentice
Have you tried this page, after logging in to the ortbi?
/QOS_main.htm
There are a whole bunch of QoS related directories in there this one looks liek it might help too.
/QOS_Dynamic.htm
- Retired_MemberJul 21, 2017
RonV42 wrote:Reset to factory isn't a acceptable solution. It would be like asking me to replace my car engine after I did maintenance.
Actually, a more accurate analogy would be to reset your ECM after doing maintenance, which is not a bad idea.
