RonV42
Dec 20, 2016Luminary
QOS on Orbi is it enabled or disabled?
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled. Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off. We need a che...
- Retired_MemberDec 26, 2016
Worked. The HTML has to be changed to HTM.
PhoenixV
Dec 26, 2016Apprentice
You have to use the syntax as follows:
/QOS_dynamic.htm
instead of /QOS_Dynamic.htm
Retired_Member
Dec 26, 2016Worked. The HTML has to be changed to HTM.
