RonV42
Dec 20, 2016Luminary
QOS on Orbi is it enabled or disabled?
Ok so I am on the QOS page and there is nothing to say it's enabled or disabled. Ran the speed test on the page and it shows the resutls but no indication of QOS is turned on or off. We need a che...
- Retired_MemberDec 27, 2016
Worked. The HTML has to be changed to HTM.
RonV42
Reset to factory isn't a acceptable solution. It would be like asking me to replace my car engine after I did maintenance.
Retired_Member
Jul 21, 2017
RonV42 wrote:Reset to factory isn't a acceptable solution. It would be like asking me to replace my car engine after I did maintenance.
Actually, a more accurate analogy would be to reset your ECM after doing maintenance, which is not a bad idea.
