BunnyS
Dec 09, 2020Aspirant
QoS Orbi RBR 50
I am using ethernet right next to the router and modem and I would like that to be the priotized connection. The moment someone goes on youtube on their phone wirelessly, the bandwidth seems to split...
CrimpOn
Dec 09, 2020Guru - Experienced User
BunnyS wrote:I am using ethernet right next to the router and modem and I would like that to be the priotized connection. The moment someone goes on youtube on their phone wirelessly, the bandwidth seems to split unevenly to them even though, I really need the speed for business meetings. Is there a way to give my Wired connection to Orbi the priority.
Not that has ever been mentioned. Orbi has some sort of "Dynamic Qos" capability that I can find no explanation for. And, Orbi's QoS is based on applications, not devices. So, my conclusion is "no".
- BunnySDec 09, 2020Aspirant
Is there a way to access this Dynamic QoS? It seems like this has been a problem for many many years.
- FURRYe38Dec 09, 2020Guru - Experienced User
It's automatic so no access thru UI.
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
- CrimpOnDec 09, 2020Guru - Experienced User
When Orbi was first released, I believe there was a method to tinker with the QoS settings (although my memory of four years ago is hazy).
There are still "QOS" web pages in the firmware, but they appear to be inactive.
I think the only obvious solution is to buy more bandwidth.
